delete file from folder
megabaza
Good day!
Need help settings.
On the local disk exist folder_1 with a file that is updated each hour for a new one.
We need from folder_1 file move to folder_2 and remove it from folder_1.
After inserting the file in folder_1 (every hour), the file should move in folder_2 and update the new file and also file needs to be deleted from the folder_1.
Moving and updating the file from folder_1 to folder_2 understand.
But it is not understand how to remove the file from folder_1 ?
