Copy from subfolders
Seven
Hi...
i want to try something and i tried like half day ..:D
So i have a Folder with subfolders, each subfolder contain a file that i want to be copyed to a specific folder without creating subfolders at the destination, is this possible ?
LapisLazuli
This can be done manually on windows: search *.* in Windows Explorer, then drag-drop the files to the target folder.
Should work similarly under other O/S.
Not sure FFS can do it.
Regards.
Just set up multiple folder pairs.
Seven
i cant do that because almost every day, a new subfolder will be created automatically
