Hello every body
Thanks you about best of free file sync software
i'm use FreeFileSync to backup data from may laptop to my external hdd,
I feel very satisfied but if i want sync data, i must open FreeFileSync and click sync
i want FreeFileSync sync data in background and if possible i want setting time to sync for it.
This is best software, i like it.
Thanks you for reading and thanks for FREE.
Feature request - Automatic sync in background
See this link: https://freefilesync.org/manual.php?topic=schedule-a-batch-job
If using windows, to sync in the background at a scheduled time, save your settings as a "batch job" then create a task in the windows "Task Scheduler" to make it run whenever you want.
If using windows, to sync in the background at a scheduled time, save your settings as a "batch job" then create a task in the windows "Task Scheduler" to make it run whenever you want.Zargron
Thanks you very much :D, i will try it.
