Good Day
I'm using freefilesync to copy data from a nas share to a usb drive. now this nas share has data on it about 2 years back. i wan't to synchronise only files which are crated for example since 01. november 2016 to usb disk. all older files should not be synchronised to usb. is this possible with freefilesync and if yes, how do i configure this?
thanks
sync all files newer than a specific date
Easy... Use the time span option available from within Filter synchronization settings.
Set it to "This month".
thanks, i have already seen this option but the predefined values are not what i need. i need custom date selection. for example 01.may 2016. all data created after this time should be synchronised, all older data should not be synchronised. and i need to save this config in a batch job.
