When I use two ways on same computer, all is fine with RealTimeSync...
Next, if I use the button to sync two ways with FreeFileSync and sFTP, it'S working fine...
Now, when I try to use Two Ways Sync with sFTP, I always get the error message:
The following path does not support directory monitoring
Is there something I am missing or it's not possible to use two ways sync with sFTP ?
What I want is to sync files between Windows client and a Linux server over the LAN. Any help to achieve it would be greatly appreciated.
Edit: I think mirror with the option 'Detect moved files' work. I've just seen this option when customizing the synchronization. First thought it was necessary to use two ways to detect deleted/moved files.
sFTP two ways not working
The error message is coming from RTS and has nothing to do with FFS or its "two way" variant.
in other words... I am using the wrong forum to ask if we can sFTP in 'two ways' with RTS ?
No, forum is right, message is from RTS, it's a limitation of SFTP.
