Versioning, Cryptomator-Webdav
gerald.12524
on Win10 Cryptomator acts as a WebDAV server and provides a virtual drive.
Normal Functions works fine. With File Versioning on this drive like this:
Fehler Das Verzeichnis "V:\ZZZ_Versionierung_FFS\2016-12-30\Datensicherung\Cloud" kann nicht erstellt werden.
Fehlercode 2: Das System kann die angegebene Datei nicht finden. (CreateDirectory)
With Versioning at local path no problem.
Gerald
Can you retry with the following version and see if this fixes the issue? I assume the problem is that one of the intermediate directories "2016-12-30" or "Datensicherung" needs to be created first, which doesn't happen because of the peculiar error code.
http://www.mediafire.com/file/cxmxw5nk7yt1d36/FreeFileSync_8.8_beta_Windows_Setup.exe
gerald.12524
this Version works fine. With creating directories by Versioning.
Thank You.
