I'm using ffs 8.7 on Windows 7 64-bit and I have sync.ffs_db in "My documents" directory. Is it possible to move it elsewhere?
sync.ffs_db location
I'm also wondering about this. I use FFS with mounted drives on Linux and if the scheduled batch file runs in the background when the drives aren't mounted, FFS creates files in my /media directories. This creates some annoying errors when I subsequently go and attempt to mount those drives. I'm not worried about performance, so I'd prefer that no database file be created whatsoever if it meant FFS would leave my /media directories alone when my drives aren't mounted.
Nobody can tell?
