ACLs setting at job level
Ipnotoad
Hi all,
maybe I'm using Copy ACLs setting in wrong way but.. I've, for example, 3 jobs that will be run manually every morning. Only one of these jobs (the second one) requires ACLs option active.
If I don't want any problem, those are the steps I have to use for executing job.
1. verify acls is disabled
2. run job1
3. enable acls
4. run job2
5. disable acls
6. run job3
Is there any way to enable/disable ACLs at job level?
Sometimes I forget point 3 and point 4 goes wrong..
Thanks!
