Synch of the new files between folder in c:\ and another folder in a device with mtp access, works very fine.
Synch freeze instead if the file is not new but it has to be updated in mtp device.
FFS ver. 8.4 or 8.7 or 8.8;
PC c:\: win7 64 bit
mtp device: Samsung Galaxy S7
file updating in mtp device, freeze & crash
Does it make a difference if you turn off Menu->Tools->Options: Fail-safe file copy?
***********Ver 8.4
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Hang" />
<EventID Qualifiers="0">1002</EventID>
<Level>2</Level>
<Task>101</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2017-01-16T20:35:22.000000000Z" />
<EventRecordID>131820</EventRecordID>
<Channel>Application</Channel>
<Computer>axxxxxxxxxk</Computer>
<Security />
</System>
- <EventData>
<Data>FreeFileSync_x64.exe</Data>
<Data>8.4.0.0</Data>
<Data>283c</Data>
<Data>0xxxxxxxxxxxxxx</Data>
<Data>33</Data>
<Data>C:\Program Files\FreeFileSync\Bin\FreeFileSync_x64.exe</Data>
<Data>49xxxxxxxxxxxxxxxxxxxxxx</Data>
<Binary>5xxxxxxxxxxxxxxxxxxxxxxxx00</Binary>
</EventData>
</Event>
*********Ver 8.8
- <System>
<Level>2</Level>
<Task>101</Task>
<TimeCreated SystemTime="2017-01-14T13:04:31.000000000Z" />
<EventRecordID>131678</EventRecordID>
<Computer>axxxxxxxxx</Computer>
<Security />
</System>
- <EventData>
<Data>8.8.0.0</Data>
<Data>233c</Data>
<Data>0xxxxxxxxxxx</Data>
<Data>29</Data>
<Data>b5xxxxxxxxxxxxxxxxxxxxx</Data>
<Binary>5xxxxxxxxxxxxxxxxxxxxxxxxxxx</Binary>
</EventData>
</Event>
- <System>
<Level>2</Level>
<Task>101</Task>
<Security />
</System>
- <EventData>
<Data>283c</Data>
<Data>33</Data>
</EventData>
</Event>
*********Ver 8.8
- <System>
<Level>2</Level>
<Task>101</Task>
<Security />
</System>
- <EventData>
<Data>233c</Data>
<Data>29</Data>
</EventData>
</Event>
What if you delete the target file manually via FFS's main dialog?
Manually deleting the first file on the mtp device side via FFS's main dialog is successful but manually deleting the second file, FFS hang up and freeze.
