Real Time Sync
sined192
Once I have created a real Time Sync how do you stop it again?
georg_m
i've got the same problem
georg_m
* Open the Task Manager (Ctrl+Alt+Del then Start Task Manager), select the RTS task or process and end it.
OR
* If you have manually started RTS: restart your computer or logoff the present user
If RTS starts automatically, e.g. at startup of your computer, or at login of a given user,
you might need to disable that scheduled task, e.g. in the Task Manager.
