Realtimesync only runs once
InspGadgt
I'm trying to set up a sync between a new server and an old to copy data that is constantly being used in order to migrate to the new server. I stumbled across this product in my search and since it is supposed to handle long file names without a problem it looked ideal. I set up a test sync using FreeFileSync, exported the batch file, and imported it into RealTimeSync and ran it. It runs great for the first time there is a change to the folder but will not continue to sync until I close the notification window that pops up every time it syncs. Is there a way to get rid of that notification and have it just continue to sync or to have the notification automatically acknowledged?
Thank you
InspGadgt
No one?
Probably, in your sync settings (F8) you have:
Not selected "Close progress dialog" under "On completion" and/or
Not selected "Ignore" under "Handle erros"
