I was wondering if it would be possible to have the NTFS permissions preservation option moved to a per-job option.
I use FFS in order to sync directories of files from remote fileservers to head office so that they can be backed up, and need to ensure that my NTFS permissions are copied.
I am concerned that when I run a sync batch job that unless I launch FFS as the account I intend on running through Task Scheduling and configuring the Global Options, that the NTFS permissions will not copy.
Also - I do not believe that FFS currently reconciles and applies changes to file/folder permissions, is that correct? That would be something that's most desireable.
NTFS Permissions Preservation
