View only files that are transferring
amucci
I am trying desperately to view ONLY the files that are going to be copied.
We recently setup a new server, and did a final sync of the data from old to new. At this point in time, no one should be using/connected to the old server. However, when I did a FileSync, it shows 13 files that need to get copied.
How can I view the files that are about to get copied from the old server to the new? The view shows me everything, even files that are the same. I tried clicking around on categories, but as soon as I choose Exclude All - (Files that are the same) no files show up in the results list,
Any help would be appreciated. Love the product, been using it for years since FileSync went away.
Did you try the "Select view" buttons mid below the left and right comparison windows?
