duplicate on the go?
adwb
is it possible to set up filesync to do the following?
when an image is added to a specific file folder direct from camera to copy that image to a second location, thus creating a back up folder that is as up to date as the original folder as the photo shoot progresses?
Not instantaneously.
But you can use RealTimeSync (RTS), that comes with FreeFileSync (FFS), for that.
RTS monitors one or more folders and its subfolders for changes, and upon detecting such changes launches FFS (or any other application you might define) to run a sync you have stored as ffs_batch file from FFS.
adwb
great thank you I will investigate that
