Just installed 8.10. When I go to start it I get an Error Pop Up.
It says: "Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access them", see screenshot.
The icon on the install file isn't the usual FreeFileSync either.
Tried running as Admin, no joy. Been running fine for ages.
8.10 Will not run
Another case of AV software heuristics going mad. It looks like I might have to push an update because of this nonsense (unless the AV prog fixes their stuff).
