Experimental FTP?
kisb
I was happy to upgrade to newest FFS 8.10, as there is "experimental" FTP. But... where? All I can see is still the SFTP button
Bobby1290
Also very happy for this, The question is where is it and how can we use it. The only thing I get is the SFTP screen.
TIA
Bobby1290
Ok, it connects in FTP if you just change the sftp:// in the command to ftp://.
Waiting for it to read all files (slow) and see if i can do a sync.
Bobby1290
The comparison ends well. The sync stops and, says there is a crashdump, then crashes freefilesync and I can't seem to find the crashdump in any pertinent folder.
Redoing this to see if I can find a dump.
Ok found them .
crashdumps sent to zenju [at] freefilesync.org
Currently only folder traversing works. The complete FTP functionality is planned for the next release.
Bobby1290
Ok, thanks for the info.
Very happy to see it this far already.
