Hi all,
I have read through and searched the forums and have not found an answer to my question.
I have 2 files that are not syncing properly. I can see that the time stamp is different in the 2 locations but it doesn't update on the sync. I would like to force these two files to sync every time the sync runs. The are critical files to the sync operation and are locked so it has to use VSS.
When the software notices that they are different for whatever reason it syncs fine.
So my question is can I force these 2 files to sync everytime? I know I'll probably have to create a different job for it.
Thank you,
Albert
Force Copy
Old question, but I have the same one. The files I'm trying to sync are database files (R>L, to an external HDD) and their modified date only seems to change once in a while.
I now use an extra script to delete the db files from the backup location, but it would be nice if one could force certain extensions to be copied always ?
