Mirror Rules
bmadams
I completed this information for each condition (see =? ). Am I correct?
I. Compare by file time and size (with Sync set to Mirror = ?)
This variant considers two files with the same name as equal when both modification time and file size match.
The following categories are distinguished:
I. file exists on one side only
o left only = add to Right
o right only = Delete Right
II. file exists both sides = do Nothing
i. different date
left newer = Replace Right
right newer = Delete Right
ii. same date
equal = do Nothing
conflict (different size) = Replace Right
You can see the (default) actions for the different sync variants per comparison category, by opening the Synchronization Settings window (F8).
When you select a sync variant (Two way, Mirror, Update), it shows per Category (=outcome of the comparison) what the associated Action is. Move your mouse over the Category or Action to see a description.
bmadams
Thanks, I will look when I get back this evening.
