RealTimeSync command line problem...
jprinting
I recently downloaded an updated version of RealTimeSync, and accidentally deleted my command line. How can I restore it?
Thanks!
jprinting
Ok, well...I dragged and dropped the BatchRun.ffs_batch document into RealTimeSync. Seemed to work, but then it appears that FreeFileSync crashes. Have I done something wrong...?
Well, if you drop something, it generally crashes ...
(Sorry, I could not resist ...)
jprinting
Hey, have you guys discontinued RealTimeSync ?
No
What makes you ask?
jprinting
Oh, that's good! Well, whenever I try launching the app I get the following message: "“RealTimeSync” is damaged and can’t be opened. You should move it to the Trash."
Is there a link where I can download the latest version? I haven't seen that... Thanks!
jprinting
Ok, so what can I do to ensure the app runs properly?
Aaah...never mind! It was a security issue. Apparently FFS is not from a "known developer," and instead of giving a straightforward error message to that effect (the way previous OSs did) in Ventura Apple just says the app is "damaged." On the Privacy and Security section of System Settings I had the option of "Open anyway." Bah, humbug! camner, 27 Sep 2023, 23:00
tephyrnex
I am seeing the same "damaged" message for Monterey. I don't get the usual option to Allow it in System Settings. However, it can be fixed from the terminal/CLI
https://www.howtogeek.com/803598/app-is-damaged-and-cant-be-opened/
The magic is
xattr -d com.apple.quarantine /path/to/app.app
