i am searching for a solution, if there is already an existing file but a different modifydate, that one of the files will get a suffix like ***.txt_old or ***_new.txt is it possible?
Existing File newer Version + Suffix
Maybe try the "Versioning" feature of FFS: Versioning
It might not be the exact solution that you are looking for but experiment with it for a while and see if fits your needs. Before you experiment with it you might do well to read this thread to avoid some common mistakes with versioning Questions About Versioning
