On mac Sierra 10.12.4 and freefilesync version 9, in synchronisation settings-mirror: there is no label when you put the mouse cursor on the category icons. So i don't understand what exactly is each icon.
By the way, can someone tell me what each icon is?
Bug on mac
Can you post a screenshot? In my thests the tooltip works on macOS 10.12.
In 1.jpg the mouse cursor is on the middle green arrow (under the thunder) and the label is "Update right item". Unfortunately you can't see the mouse cursor, because i took a screenshot on mac.
In 2.jpg the mouse cursor is on the thunder (above the green arrow) and there is no label showing.
So i don't know what is the meaning of the thunder and the other symbols.
So please can someone explain what is the meaning of these 5 symbols? I cannot work the software if i don't know that...
If you hold your mouse over any of the 10 (2 rows of 5) icons shown,
a compact clarifying text will show (or should be shown).
In Windows, the (top) thunder shows: "Conflict/item can not be categorized"
The top row shows the comparison result categories,
the bottom row the associated action per category.
The Two-way, Mirror and Update sync variants have pre-defined actions;
modifying any of those will make it into a Custom sync variant.
No! When i hold my mouse over the icons of the up row, there is no text shown! And this is a bug happening on my mac.
When i hold my mouse over the icons of the down row there is text shown.
Well, until Zenju might be able to fix that:
Top row sync setting icons
* Left-icon: Item exists on left-side only
* Mid-left icon: Left side is newer
* Mid icon: Conflict/item can not be categorized
* Mid-right icon: Right side is newer
* Right icon: Item exists on right-side only
Thanks so much!!!! You are very kind!
