[request] Publish FFS to Windows Store please
ekop
If you need funding publish FFS to Windows Store as paid app and tell people at Windows Central so they can promote it to larger audience
I'll purchase FFS if you decide to publish it to Windows Store even if I can get FFS for free here
There's a lot of trashtalk about Windows Store and Windows security but the truth is the solution for that is Windows Store
I'm using 10 pro and I deliberately lock my PC to only trust/install from Windows Store to get Windows 10S security and safety
If FFS available in Windows Store I don't have to disable some security option just to install FFS and people who using 10S also can install it (10S locked only to store install and have no option to disable it)
Thanks for making FFS :)
