Problem working on windows 10 with non administrator user With locked Files
Eldad
Hello
Great tool.
I tried to run it on windows 10 with weak user.
when the file is locked the volume shadow copy prompt error message with access denied.
any suggestions ?
Did you bother to read the FFS manual page on VSS:
https://freefilesync.org/manual.php?topic=volume-shadow-copy
and then particularly the 2nd bullet in the note ...
Eldad
I see it now . thanks.
is there away or workaround to run this tool and use VSS with user that is non administrator ?
or away to change VSS work with user that in non administrator ?
You should ask Microsoft that question.
And you know how responsive they generally are ... :-( ,
particularly on topics that they do not deem very important.
