I want to install 9.1 on my laptop. But get the message:
"This app can not be run on the PC"
I am using Win10 home
Sorry, but English is difficult for me, if possible please reply in German.
Thank you and greeting
Install 9.1 on Laptop not possible
Try to unblock it:
How to Unblock a File in Windows 10
https://www.tenforums.com/tutorials/5357-unblock-file-windows-10-a.html
Thank you for the message, but that is not the solution.
It does not even come to the security question.
It comes immediately the message: See appended picture.
Translation of the message:
Thank you and greetingThis app can not be run on the PC.
Please contact the software publisher,
To get a suitable version for your PC.
Try this:
- clear your browser cache
- re-download the file from this link https://freefilesync.org/download/FreeFileSync_9.1_Windows_Setup.exe
The downloaded file FreeFileSync_9.1_Windows_Setup.exe must be of exactly 12,620,128 bytes.
Try to install.
Try to install.
The download did not work, the file had 0 bytes. I think the virus scanner caused the problems.
I then directly "run" selected without save and then it worked.
Many thanks for the help.
It's done now.
greeting
PS:
I translate the text from Google. I do this the first time.
Is the text OK?
It's done now.
greeting
PS:
Is the text OK?
Yes, enough!I translate the text from Google. I do this the first time.
Is the text OK? KlMeMu, 21 Jun 2017, 15:14
