I was using SynctToy for years, and I changed to FreeFileSync and I have some questions:
1. Due to the fact that I "oftenly" Reformat my computer, I want to backup the configuration of the Sync "pairs" to continue working with them across windows reinstallation processes. Can anyone tell me where does the FFS saves this config info?
2. Can I config a sync only to one direction? this is, not bidirectional sync. Instead, a only one direction sync?
Regards
Backup FReeFileSync config
1) Save your configuration using menu File, Save/Save as or use the buttons on the toolbar
2) Under Synchronization settings (F8) choose Mirror ->
