I somehow have removed the Save/load configuration menu, how can I get it back please?
Save/load configuration menu missing
Menu Tools, Show "Configuration" or Reset layout.
[Unfortunately I don't have that option, just:
Global settings
Language >
Find..
Export File List..
Global settings
Language >
Find..
Export File List..
I'm on version 6.2 BTW
I can't help you, I'm on the latest Windows version, 9.2.
Thanks anyway.
Update to the latest version so you gain the new menu options!
Did you try:
Tools/Reset Layout
or
Tools/Options/Show hidden dialogs again
(Tools being the top left in between File and Help)
Tools/Reset Layout
or
