Scheduling tasks issue
jpmeiring46
I have setup FFS and the required tasks in Task Scheduler to run 2 different batch jobs.
The issue I am getting is that the tasks, or atleast one in specific is not runnig as often as specified in the task, some times does not run at all till manually initiated in FFS.
Is there a simpler way of setting up the tasks to run for real time sync?
Regards,
JP
Gianni1962
Is there a simpler way of setting up the tasks to run for real time sync? jpmeiring46, 07 Aug 2017, 07:59
Sure, use the FFS companion: RealTimeSync!
https://freefilesync.org/manual.php?topic=realtimesync
