FFS 9.3 and SFTP: CURLE_FTP_COULDNT_RETR_FILE
Psycho85
With 9.2 my Script works pretty fine
now with 9.3 i get errors from all my Folder Syncs
(Subfolders)
Das Verzeichnis "ftp://192.168.2.40/Backup/Bastian/Files/FreeFileSync/Vereinsdaten/Alte Vereinskasse Export" kann nicht geƶffnet werden.
CURLE_FTP_COULDNT_RETR_FILE: RETR response: 550
550 Backup/Bastian/Files/FreeFileSync/Vereinsdaten/Alte%20Vereinskasse%20Export/: No such file or directory [curl_easy_perform]
The current FFS beta includes a bugfix for FTP, which probably solves your issues, too:
http://www.mediafire.com/file/2su1ou82uaud8xy/FreeFileSync_9.4_beta_Windows_Setup.exe
magnusb
I'm getting similar errors, and when trying the beta version, it crashes.
Confirmed. We have a nasty codegen bug in latest VC update. It seems to affect only the 64-bit executable.
