I have a Folder with 2.280.865 files (size: 2TB). I get the error Message "Nicht genĂ¼gend Arbeitsspeicher. Memory allocation failed: 33554467 Bytes" The error occurs on "Items found: 4.456.009"
Synchronisation is set to "Mirror"
OS: Windows 2008 Storage Server 64bit
RAM: 18GB
RAM usage when error message occurs: 7,19 GB
Is there a Limitation on the number of files (FAQ says "no")?
Thanks for help
Thomas
33554467 Bytes is approx. only 32 MB. Reason for the memory allocation failure is likely RAM fragmentation or some server limit on the maximum working set size.
