Cloud Folder Selection
gcm70
i have installed on the machine Windows Server 2003 FreeFileSync version 9.3 of the 20/08/2017.
I can't find the mode to make the sync with ftp. In my installation I can't find the button to set the data connection to the ftp server. The key cloud is not present next to the browse button.
I've attached a screenshot of my FreeFlieSync
Giacomo
Gianni1962
Hi Giacomo,
I'm on Windows Server 2008 R2 Foundation so I don't know if it is applicable to your configuration.
Anyway, start "Server Manager" and check if in Funzionalità are installed the following:
Funzionalità di .NET Framework 3.5.1
Esperienza desktop
Try first "Funzionalità di .NET Framework 3.5.1".
HTH,
Gianni
Cloud sync in FreeFileSync is not implemented for XP and Server 2003.
