After upgrading to version 9.3 from something really old like 5.x it broke my existing backup configurations so I'm starting from scratch. I created a backup and batch file, set it to wake the machine and run at 6:00 AM today but it failed with Error Code 31: A device attached to the system is not functioning. [FindFirstFile].
I should point out that I'm backing up to the same NAS box that I was successfully using with the previous version (call it my Z drive). And just before the error code 31 message was: Cannot read file attributes of "Z:\".
However, I then ran the sync manually with no problems (so during a manual run it talks to the Z drive just fine).
I looked on your site for a list of error codes but can't find one. I also did a search on the forum but can't get below 992 results because the search tool refuses to allow numbers so "31" is ignored (even using Advanced Search).
Thank you,
Mike
Error Code 31 and don't you have a list of codes?
Note that drive mappings (e.g. your Z:-drive) are user specific.
Make sure that your scheduled task is run under user credentials for which a Z-drive is defined
and mapped to the intended location. And has suitable read and/or write rights there.
Conversely, instead of using drive-letter mappings you can refer to the network address
(e.g. \\[IP-address]\[ShareName] ). This is user independent.
Obviously, the user under which the scheduled task is run still needs to have
suitable read and/or write rights in the respective locations.
Thanks Plerry.
Does that error code sound to you like a credentials problem? It doesn't to me, but as I said, I can't find a list of error codes on the website.
Yes, I do have the Windows Task authored by myself as Admin, same as I did when things worked before the upgrade.
Also, if user credentials or read/write rights on the Z drive were an issue, wouldn't that mean that it would also fail when I attempted to run the batch file manually? I have run the config file manually from within FFS and ran the batch file by double-clicking it in Windows Explorer, both successfully.
Running a scheduled task with the following option set
[x] Run with highest privileges
will cause similar credentials problem?
Thank you for that tip Gianni1962.
Actually I might be a victim of the opposite: upon examination I find that my old backups were set to run with highest privileges but my new backups were not! I have set the new backups to run with highest privileges and will see what happens at the scheduled times (tomorrow at 6:00 AM and 7:00 AM).
I'll post back afterwards.
Gianni1962 thank you for the tip. Setting the Task to "Run with highest privileges" seems to have fixed my problem.
Plerry, I must say that I'm puzzled that this has indeed turned out to be a credentials problem as you first suspected. I never would have gotten that from the error message. Thank you for the valuable information regarding drive mappings, credentials, etc. All of your information I either didn't know or hadn't thought of.
Resolved! Many thanks!
I've added a new FAQ item with solutions to common network problems in combination with Windows Task Scheduler:
https://freefilesync.org/faq.php#task-scheduler-network
