Last run timestamp
thwaller
A great option to have is to show a timestamp (date and time) of the last run of each configuration showing in the upper left corner. This is something I really miss having from GoodSync. I run many syncs and most often not all at the same time. For example, I will sync A,B,D while I am working on C,E. etc. Many of these are subsets as well. It would be nice to look and see right away which I have run for the current backup session vs needing to remember which were and were not run and when.
Also on the folder pair listing, an option to expand and collapse would be great. Just listing all is fine for 1-3 parings, but when you make 10+ pairings, it becomes a waste of real estate.
A new column showing days since last sync has been implemented in FFS 9.7.
