Hello together,
I am wondering, why all copied files get the timp stamp of the copy process and not the original one. Is there a reason, why the original time stamp is not copied, too?
Regards,
elchico
Time Stamp of copy process
Which protocol do you use to connect to your left and/or right locations?
E.g. most implementations of FTP do not support copying the original timestamp,
but use the time-stamp of the moment of copying.
Hi Plerry,
I was using Netdrive as a third party product for my FTP connection so far, but if FreeFileSync would support this time stamp transfer, I would change towards FFS.
Is it in general a problem of FTP or a problem of the softwares?
Regards,
elchico
Regards,
elchico
but use the time-stamp of the moment of copying. Plerry, 19 Sep 2017, 12:15
I believe most modern FTP servers support MFMT (= support for setting modification time), but legacy servers don't go away fast in the FTP world. When available, FreeFileSync uses MFMT.
ok. Thank you very much. Then I'll change to FFS instead of Netdrive.
Regards,
elchico
Regards,
elchico
okay, I wrote the respective FFS-file with FTP connection and "compare date and size" + ignore 1 min offset. But when I open + save + close a ppt or word file, FFS does not copy the new file, even after 3-5 min after change.
I have attached the respective file.
Have you an idea for this?
Regards,
elchico
Regards,
elchico
- BatchRun - Kopie.ffs_batch
- (1.55 KiB) Downloaded 162 times
Did you press the Compare button?
yes. But there were no files to update / copy.
Did you push the Compare button? Gianni1962, 20 Sep 2017, 08:22
Try leaving blank the value in "Ignore time shift" in Comparison settings.
Did not work neither.
To clearify: I have modified a powerpoint file by adding the letter "a" in a textfield => size of the file is the same, but not the modification time.
It is not copied / not marked as newer anyway.
Regards,
elchico
Regards,
elchico
Try leaving blank the value in "Ignore time shift" in Comparison settings. Gianni1962, 20 Sep 2017, 10:37
Are you sure the file is in the D:\Promotion folder or subfolder?
Try to set the "Synchronization settings" from Update to Mirror.
While debugging this problem keep blank the value in "Ignore time shift" in Comparison settings.
Okay when I use mirror, it shows that all! files on the right side are newer for some reason (incl. my modified file of course). So probably my FritzBox runs with a different time zone (2 h in the future). But I do not know why yet.
So thank you very much.
Regards,
elchico
Regards,
elchico
Hi everybody,
same problem, different reason: When I copy manually (by drag&drop) a file to the USB drive at my FritzBox, it gets the time of the copying process. But when FFS copies a file to the FB, the file gets a time 2 h in the future of the copying process. Does somebody know why? Because this is really bad when I want to update my files more often than every 2 h.
Thank you and regards,
elchico
elchico
Do you get a warning message about MFMT failing?
yes, it says, that the server does not accept MFMT. But why is then there a 2 h difference?
Only the FritzBox knows... As far as FFS is concerned, it couldn't set a file time.
Okay, thank you :-)
Then I have to consider a work around ;-)
Regards
Regards
