webdav and file modification time
frankv1512
I use FreeFileSync to backup some of files to a webdav folder (in mirror mode if that is relevant).
Unfortunately, the modiefication time stamp of original file is not copied to webdav, so comparing files based on size + timestamp fails copies files over and over.
The webdav server (Nextcloud), is able to preserve modification time stamp on files, because moving files manually does not change the timestamp
It there a way to fix this, so FreeFileSync also preserves modification time on files?
Kind regards,
Frank
DerFlo
Hello Frank !!
I do have the same problem. Wueld be nice that freefile has the cabaility to use also Nextcloud for syncing.
Best greetz
