Recently upgraded to 9.3. Using the Browse to locate files to copy, FFS displays no files in any folder. The file list area says ... "No items match your search". ALL folders, ALL files.
If I drag and drop a file to the Relative Path box, the pathname displays above normally ... but the file is not listed in the Relative Path list ... and the Browse still shows no files.
I uninstalled, rebooted, downloaded a fresh copy, and installed again.
Same thing.
Any ideas?
Many thanks.
FFS sees no files in any folder
The Browse button behavior is by design, it must show only folders.
To have (eventually) something shown in the "Relative path / Date / Size" list you must first press the Compare button.
