Just started to use FFS again, after a long while - possibly last used it with Win 7.
I am now finding that Windows shuts down when an FFS batch file is run.
Message is similar to: "Windows is disconnecting and will shut down in 1 minute".
I have not had this behaviour before, and it only seems to occur when the batch file is run.
I can load/start FFS and it will sit there happily for hours, only when it's run does the error event occur.
Any ideas please ?
Thanks.
FFS turns off Windows 10 ?
Could be a "on completion" command you've set for the ffs_batch.
Thanks,
I'll have to check it out tonight when at home.
