Compare Problem
B.Anders
Hi, i just installed FFS and testing, with following result:
Left i have a Drive D:\ as path and right External Drive E:\Backup
Destination and source are identical as i manually copied all content prior to installing FFS.
When i compare, FFS doesn't find any match and shows all files left with +> and all files on the right with <+
I have tried all compare methods with same results.
If i compare just 2 of the subfolders, it shows that they are identical
D:\Folder1 = E:\Backup/Folder1
What am i doing wrong ?
Thank you,
B.Anders
Gianni1962
Please post some screenshots showing the problem.
When doing backup use Mirror as Synchronization variant and Versioning as the "Delete files" option.
Read carefully and test on not important files and folders.
Versioning
