Free File Sync won't let me open up network files that are mapped as shared network drives in Windows (ex: Samba shares from a Linux computer).
- If I try to open the mapped drive from Free File Sync the mapped network drive doesn't exist in the GUI window to open up FreeFileSync script files.
- If I navigate to it in Windows Explorer and click on the .ffs_gui file it gives this error:
cannot open .ffs_gui files from mapped Samba shared drives in Windows
UPDATE: If I navigate using the IP address instead of the mapped drive letter it *does* work.
Ex: "\\192.99.99.99\pi\1GB\backup.ffs_gui" works, but "Y:\pi\1GB\backup.ffs_gui" does NOT.
Looks like a bug. Can you fix this please?
Drive mappings are (Windows) user dependent.
Do you run FreeFileSync (FFS) under the same (Windows) user credentials as the one for which the drive-mapping is defined?
