I'd love to see a "sort" asending/descending option added to both source/destination columns. Obviously the sort would also have to keep the matching file path on the other side of the compare when it happens.
Keep your backend logic as to order of operations in what gets done and in which order, but having the display be sortable would be great. Some lists can get quite long and had to pick out specific entries when it is displayed in entry order.
Thoughts?
Sort option available?
Isn't there already?
I don't see it?
To be clear: I'm taking about the file lists, not the compare results.
Are you saving sync configurations? In this case manual reordering is possible (via ATL+PgUp/PgDown)
