I just downloaded v9.4 (Windows) from this website. As soon as I double-click the install file it self-deletes. Nothing gets installed. What's happening?
Peter
v9.4 Install File Deletes When Run
Probably your antivirus is the responsible of the deletion.
Strange that is doing that silently.
What is your antivirus?
Anyway try updating its definitions then re-download FFS and try again.
Thanks for the reply.
I'm not saying it can't be my antivirus but I've never seen it delete something silently with no notice in its log. Virus definitions are up to date. I will try again later and temporarily disable my AV when doing the install.
Peter
Peter
