Installed version 9.5, doesn't launch on ubuntu 17.04:
"./FreeFileSync: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.11' not found (required by ./FreeFileSync)"
I reverted to 9.4, which solved the issue for now.
9.5 does not run (Ubuntu 17.04) /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.11' not found
Upgraded to 17.10?
Nope, running 17.04
(updated the title and first post)
That's the problem.
Well, upgrading the OS as soon as the new version is available isn't always possible or desirable, so this is an issue :/
I just tried getting the '9.5 for ubuntu 16.04' version => "error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory"
- will there be a 9.5 for ubntu 17.04 ?
- The "FreeFileSync 9.5 Debian 9.2 64-bit" version seems to work OK on Ubuntu 17.04.
(and while I'm whining, an apt repository would be great ^^)
