I've found a bug. When I repeatedly synchronize (F9) the same folder WITHOUT change synchronization set into another and back to the same synchronization doesn't check for changes at all. It shows no changes hence nothing is copied/deleted.
Any suggestion apart from remembering to change set to other and back?
Kind regards
Gabriel
Repeated synchronization of the same folder (F9) doesn't check
Press first the Compare button and then the Synchronize button.
See also: Bug? - Post by dummy - 13 Jul 2017, 22:07
