How disable sound in V. 9.5 ?
pblacky
I installed v 9.5 a view minutes ago and now i have a sound after completing a sync via batch!
please let me know how to disable this sound!?
You can remove the notification sound from GlobalSettings.xml or just delete gong.wav from the installation folder.
pblacky
worked perfect, thank you!
New with FreeFileSync 10.13: notification sounds are managed via the global options dialog
