SetValues failed for WPD_OBJECT_DATE_MODIFIED
ErnieG
When trying to sync to my HTC-M9 I receive the following:
Cannot write modification time of "mtp:\HTC One M9\HTC M9\SD MEDIA\MUSIC_LIBRARY\MP3_XFR\MP3_LIBRARY\FOLDER.6b6a.ffs_tmp".
IPortableDeviceProperties::SetValues failed for WPD_OBJECT_DATE_MODIFIED.
HRESULT: 0x80070005, Access is denied.
I have admin access on both my PC and my phone.
(My HTC is NOT rooted.)
FreeFileSync Version: 9.2; Jul 3 2017 - Unicode x64
Thank-you!
E.
ErnieG
My bad! I found a reply to an earlier posting for this issue. I am currently running Android-7. The previous post states that this should be fixed in the Android-8 release.
(BTW- I found the response via a Google search. Using the forum search for the error " WPD_OBJECT_DATE_MODIFIED" did not return any results??")
Again, thank-you to all!
