Showing 0 files of 11,000,000
I am trying to run a mirror copy of an email file storage from one server to the other. The Comparison runs for quite a while and completes. The window however remains blank with no files showing and the status says Showing 0 files of 11,000,000. When I click the Sync button it completes immediately and states there was nothing to do. Any ideas on how I can get this to work?
Check your filter settings: https://freefilesync.org/manual.php?topic=exclude-items
They are the defaults.
I left it after it completes the compare and it never shows the files listings.. both window panes are blank and still says showing 0 of 11,731,555 rows. Seems to be a bug in the app. Please advise a fix or work around.
Check your view filter setting at the bottom.
If all files left and right are equal, the compare-result window will be empty,
as FFS does (by default) only show the differences (with intended actions),
and the conflicts (if any) that FFS can not resolve on its own.
If you (also) want to see the equal files, press the "=" icon below the compare results
(as Zenju effectively says).
