Only selected folders of a set should be saved?
tino77
one question regarding the backup function.
I made a new set which contains 5 single folders.
The data is 25 GB = 8.000 files.
If I synchronize – it will start the whole set.
Is it possible to make a selection – that only 3 of the five folders wll be synchronized?
Gianni1962
Save your configuration/sync set to a file.
Remove those folders you don't want to sync and execute the sync.
Then, when asked, choose don't save the modifications.
Let's not forget the IMHO preferred solution of creating multiple configurations and dynamically merging only those that you need at a specific time: https://www.youtube.com/watch?time_continue=1&v=MEXPm1KEHL8
