Batch Job on completion with time variable
Henning8
Hi there,
I would like to open an explorer window of one side after completion. I use a folder with \%date%\%hour%-%min%\ for synchronization. But when I use "explorer /select, "%item_path2%"" I get an explorer window showing a generic folder like documents.
What is my mistake?
Thanks,
Regards
Henning
Gianni1962
Right click, Show in Explorer
already take care of the side on which you are.
Henning8
thanks for your reply.
I think I tried that as well without success. But my question was regarding a batch process.
Gianni1962
I don't understand what you mean saying that your question was regarding a batch process, those special Macros are available only in the file lists.
User Manual - External Applications - Macros
Henning8
I found out that executing a program after completion has vanished in the verison 9.5.
Then I have a feature request. Would it be possible to open the explorer window automatically after completion of a batch job even if it contains a date or time variable?
Thanks,
Regards,
Henning
Gianni1962
May be has changed location, now it is in the Synchronization Settings panel [F8]
Run command after synchronization:
On completion:
On errors:
On success:
Try it!
