ftp server
iam unable to connect to other server
Can you please elaborate? What are you trying to do? What error(s) are you seeing? What does the log say (maybe here: %appdata%\FreeFileSync\Logs)
i have added ip address, i am getting timed out error always
connection type is FTP, i have added ip address and user name and password.
when i try to browse directory on server. Iam getting timed out error always
I have to admit that at first glance, this doesn't seem like a problem directly related to FFS.
To rule out this being a problem with FFS, can you please try and connect to the FTP using another software?
What operating system are you using?
windows 7, ftp is working fine with other software(FileZilla)
i have successfully getting files from server
but by using realtimesync, iam getting error as " The FTP protocol does not support directory monitoring: "
It seems that FTP can't monitor changes with RTS ??
That link to the post and the complete thread should answer that.
FTP simply does not support directory monitoring
