Ubuntu 17.10. as a fresh install, not an in-place upgrade, so no leftover junk.
canonical, canonical-partner, community-maintained, and restricted repositories are all enabled.
gcc-6 - version 6.3.0-12ubuntu2 is installed.
libstdc++6 and libstdc++-6-dev are both present.
There are no versions of libstdc++ with anything remotely like ".so.6" in the repositories, so that part is questionable information. A search for it returns no results.
Next steps??
/usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.11' not found
Sorry, forgot to put that this is for FFS 9.5
No such file like "/usr/lib/x86_64-linux-gnu/libstdc++.so.6" or similar, but "libstdc++6 and libstdc++-6-dev are both present"? Are you on 32 bit?
I have the same problem.
I am using ubuntu 17.04 with FreeFileSync version for ubuntu 17.10 because the link for 16.04 is not working
Why not update to Ubuntu 17.10?I am using ubuntu 17.04 with FreeFileSync version for ubuntu 17.10 patilanz, 06 Dec 2017, 11:50
I am using Ubuntu 17.04 64-bit and neither "Download FreeFileSync 9.6 Ubuntu 17.10 64-bit" or "Download FreeFileSync 9.6 Ubuntu 16.04 64-bit" work at all.
they throw up "./FreeFileSync: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.11' not found (required by ./FreeFileSync)" error.
I am using "Download FreeFileSync 9.6 Debian 9.2 64-bit" as it works correctly on "Ubuntu 17.04 64-bit"
on Ubuntu 17.04 64-bit system
"Download FreeFileSync 9.6 Ubuntu 17.10 64-bit" throws up "./FreeFileSync: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.11' not found (required by ./FreeFileSync)" error.
"Download FreeFileSync 9.6 Ubuntu 16.04 64-bit" throws up error "FreeFileSync: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory" error.
"Download FreeFileSync 9.6 Debian 9.2 64-bit" throws up no errors at all .the program appears to run correctly as far as I can tell.works for me.
