Multiple error messages 5, 32, 80, 183
pipsqueak126
I've been using FFS for a few years now and it's always run fine in the background, copying files from one shared network drive to another. However, recently the process has been interrupted by multiple errors each time. These are most commonly error 5, error 32, error 80 and error 183. I have attached a few screenshots. I run FFS via Task Scheduler every hour.
Any help is greatly appreciated.
The first two error messages seem legit. Or do you think the "already existing" is not correct?
The last one seems to suggest that some other application is messing with the file copy. Badly-behaved AV software can be one reason: https://freefilesync.org/faq.php#different-after-sync
